Effective and modal mass for a cyclic symmetric model
Question - Why effective mass does not match total modal mass for a cyclic symmetric model?
Answer - We can’t use the same guidelines about effective mass ratio for cyclic modal as we would with non-cyclic models. The effective mass won’t match for cases other than Harmonic Index=0.
As per the help document: For cyclic symmetric models, the participation factors are only provided for HI=0 and 1, and these values are multiplied by sqrt(N) and sqrt(N/2) to match a full 360-degree model.
This is described In Section 4.1.7, please see the section below:
