Defining stiffness and Damping as a function of time
Can we define stiffness and damping as a function of time?
Yes, it is possible to define stiffness/damping as a function of time in RBD. One can either write the Python script directly or use the variable load extension. Attached is a simple test case. It defines time-varying stiffness or damping using a Python table. Note that this model needs to be solved in meters.
Reference: Ansys Help documentation for Variable Load extension: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_sim/rbd_using_var_load_ext.html
Download the accompanying files here. Download Ansys Student for free here.
