TUI Command for Calculate PDF Table Option
Is there a TUI command corresponding to Calculate PDF Table?
If the user wants to correct the settings or just to enable non-premixed model using TUI commands then an equivalent to the GUI "Calculate PDF Table" is that the user has to answer “yes” to "Create PDF Table?" while setting up non-premixed combustion model using TUI commands (e.g. within a journal). This will create PDF table.
define/models/species/non-premixed-combustion?
;Enable the non-premixed combustion model? [yes]
yes
;Create PDF Table? [no]
yes
