Optimizing Result Import Time — Lesson 6
Is it possible to decrease the time required to import the results files into ANSYS nCode DesignLife?
Yes. By default, the option to view the FE results within nCode DesignLife software is active (i.e., “ON”). You can turn that option OFF, which will decrease the import time but prevent viewing the FE results within nCode DesignLife software. Note: The time required to import the results files into nCode DesignLife software was an issue with early versions of the program, but performance was improved in R18.1.
