How do I determine the volume of a cloud with a certain range of a species concentration?
First, mark the cells with a species mass fraction INSIDE of ISO-MIN and ISO-MAX under ADAPT >ISO-VALUE ADAPTION. Then, split the register in the fluid zone under Mesh->Separate->Cells. Calculate the volume of the resulting new fluid zone under Report->Volume Integrals->Volume.
If the split operation fails or you have several fluid zones, do the following:
