Extract Deformed Faces in Ansys Mechanical software — Lesson 9
How can I extract the deformed faces of a body after a static analysis?
The Surface Coating provides a method to extract the deformed faces of a body:
1. Insert a Surface Coating and select desired faces for extraction.
2. After the solution, you can extract the deformation results based on the Surface Coating option.
3. Hide all other bodies except the Surface Coating, and export result using .STL file option.
4. Set the display option to Result only.
