Predicting Fatigue Life using E-N Approach
Do you have an example of E-N approach to calculate the fatigue life under time series loading in nCode DesignLife?
The E-N approach typically relates to situations where some of the cyclic loads are relatively large and have significant amounts of plastic deformation associated with them, together with relatively short lives. This type of behavior is commonly referred to as low-cycle or strain life fatigue, although it is perfectly valid to use the E-N approach even in a high-cycle situation. The following attachment describes the Stress-Life approach to calculate the fatigue life of an innovative mountain bike frame design under time series loading.
Please refer to the attached model to understand the steps.
For more details, please refer to the document below.
