Defining Heat Transfer Coefficient
How to define heat transfer coefficient?
The heat transfer coefficient is a characteristic of the flow. It is used to measure the ability of a flow to convect energy from walls. HTC= qwall/(Twall-Tref)
For forced convection flows, HTC is traditionally conceived to be a function of velocity (flow rate), fluid properties, and geometry. i.e. NU = HTC/KL = NU(Re,Pr); it is not thought in terms of wall boundary conditions. This is true only if Tref is a bulk (or "mixing cup", or mass-averaged) fluid temperature. For constant properties, by this definition, HTC becomes independent of thermal field.
There are at least 3 methods in calculating HTC in Fluent software. The first two use heat flux to get HTC, which requires a converged thermal field. In these two methods, HTC is determined by measuring the thermal
field - by measuring heat flux. The 3rd method does not require to run the thermal field.
1. HTC=qwall/(Twall-Tref)
Tref is defined by the user in the Report->Reference Values. This HTC is an Ansys Fluent variable; it can directly be selected under 'Wall Fluxes'. This cannot be used if the bulk temperature changes along the flow direction, which gives it a limited usage. For example, it can't be used for flow inside a heated duct or a
pipe, because the bulk temperature changes along the pipe. In these cases, this HTC becomes a fictitious value; it may be good only for that reference temperature. If it is going to be applied as boundary condition for another simulation or FEA analysis, it may only be used with that reference temperature
- a fixed thermal boundary condition.
But it can be used for flow over a flat-plate, where the reference temperature far away from the plate remains unchanged in the flow direction. (For flat plate, the bulk temperature turns out to be temperature at infinity.)
2. HTC = qwall/(Twall-Tcell)
In this definition, Tcell is the adjacent cell temperature. This definition is much better than a fixed reference temperature for most complicated geometries. In most cases, if wall functions are used and Y+ is obeyed, the adjacent cell temperature becomes close to the bulk temperature. (Note that when using standard wall functions, the Y+ at adjacent cell, ideally, should be between 30 and 60, mostly depending on the application.)
This definition cannot be applied for two-layer model where the first node is too close to the wall. In this case the adjacent cell temperature will be much higher than the should-be-used bulk temperature. This will over-predict HTC.
In practice, one may apply a constant wall temperature - value that is close to actual value, and a fluid inlet temperature. Converge the thermal and the flow field and then extract this HTC.
To get this HTC in Ansys Fluent, you can make a Custom Field Function (CFF) of the following existing
Fluent Field variable
HTC = ('Total Surface Heat Flux' - 'Radiation Heat Flux')/('Wall Temperature
(outer surface)' - 'Static Temperature').
You can perform contour plot of this CFF without the node values. Without the node value 'Static Temperature' will grab the adjacent cell temperature.
Note that in order to use q"/(Twall - Tcell), there has to be sufficient flux through the wall.
3. Another method to obtain HTC is to get it directly from wall functions. Note that this method can be used even if there is no flux through the wall!
For segregated solver, incompressible flow, and Ystar > Ystar_T: Tstar=(Twall-Tcell)*Density * cp * Cmu^.25 * kcell^.5/qwall = Prt * [1/k *ln (E * ystar) + P]
HTC = qwall/(Twall-Tcell) = Density * cp * Cmu^.25 * kP^.5 / {Prt * [1/k *ln (E * ystar) + P]}
For segregated solver, incompressible flow, and Ystar>Ystar_T: Tstar=(Twall-Tcell)*Density * cp * Cmu^.25 * kcell^.5/qwall = Pr * ystar
HTC = Density * cp * Cmu^.25 * kP^.5 / (Pr * ystar)
where P = (pi/4)/sin(pi/4) * (A/k)^.5 * (Pr/Prt - 1) * (Prt/Pr) ^.25
