If your base is smaller than inflation height, then try to use "Maximum Height over Base" to a number greater than 1. With this you will be able to get the inflation height taller than the base size.
You are being redirected to our marketplace website to provide you an optimal buying experience. Please refer to our FAQ page for more details. Click the button below to proceed further.
