Setting Up Peripheral Swirling Inlet Flow
How to Setup Peripheral Swirling Inlet Flow in Ansys Fluent?
In some applications like jet milling and flow separation equipment, simulation setup may demand a peripheral swirling inlet from a cylindrical surface. The attached solution explains the setup of the in-built boundary conditions (mass-flow-inlet or velocity-inlet) in such a scenario.
You can access the relevant files by clicking on this link: Download Files
For more details, please refer to the document below:
