Setting Up Non-SI Unit for a Boundary Condition Input Parameter
How to set a non-SI unit for a boundary condition Input Parameter value in Fluent?
This Solution shows on how to use lbm/min as a massflow boundary condition value, instead of kg/s. The same can be applied for any other boundary condition values.
Please see the attached PDF for a detailed description:
