Exporting vrml Files for Transient Cases
In Ansys EnSight™ simulation data visualization software, while exporting the transient file in vrml file format, only the current time step file gets saved. How do I go about exporting vrml files for a transient case?
This can be done using a python script to export in vrml format. The python script is as follows:
for x in range(20):
ensight.solution_time.current_step(x)
ensight.solution_time.update_to_current()
ensight.part.select_begin(6)
ensight.part.visible("OFF")
ensight.savegeom.format("vrml")
ensight.savegeom.begin_step(x)
ensight.savegeom.end_step(x)
ensight.savegeom.step_by(1)
ensight.savegeom.save_geometric_entities("D:/test_pyscript_" + str(x))
In order to implement the script, go to File --> Command. Select the Python tab in the pop-up window and select New Python file… Copy and paste the script into the editor.
You will have to make a few changes to the script.
Line 1: for x in range(20) - you can change the number to the number of time steps you desire.
Line 4: ensight.part.select_begin(6) – The number is the part Id which is shown in the Part window (located left of your screen by default)
Line 10: ensight.savegeom.save_geometric_entities("D:/test_pyscript_" + str(x)) – You will have to set the location of file storage by replacing the text in “ ” by the location you want the files to be saved.
To execute the Python script, in the Python editor window, File --> Run Script (execfile).
