Using Multiple Separate Particle Injections
How to use multiple separate particle injections in Ansys EnSightâ„¢ simulation data visualization software?
It is not possible to use more than one particle part for one case. This is a limitation of the Ansys EnSight Case Gold format. Particles are described as a "measurement" point cloud.
The only known workaround is to use multiple cases for the different injections. Ansys EnSight software can open up to 16 cases simultaneously. By referencing the same *.geo file in all *.case/*.encas files it is possible to limit the data volume.
Then load only the particle part for all but the first case.
