Creating an Isosurface at the Boundary Layer Edge
How to create an isosurface at the boundary layer edge in Ansys EnSightâ„¢ simulation data visualization software?
1. Select the wall part and open the Calculator. Use the BL_Thick function. This will create a scalar on the wall part equal to the boundary layer thickness.
2. Select the wall part. Go to Create > Elevated Surfaces. Choose BL_Thick as the variable and set the scale to 1.
