Damping Controls in Harmonics Acoustic Analysis
What are the damping controls available in Harmonic Acoustics Analysis?
The Damping Controls category is visible when Structural Physics is turned On. These properties enable you to specify damping for the structure in the Harmonic Acoustics analysis. Properties include: Structural Damping Coefficient, Stiffness Coefficient (beta damping), and Mass Coefficient (alpha damping). They can also be applied as Material Damping using the Engineering Data workspace. For more on damping controls available with Harmonic Acoustics Analysis, please refer to the following Ansys help link:
Ansys Help Link
