How to define contact between two acoustic bodies? How to connect dis-similar acoustic element meshes? Is there an example for using contact between two acoustic bodies?
Defining contact between two acoustic bodies does not require any special settings. You just need to define the MPC bonded contact between the acoustic domains, which automatically sets the Contact element Degree of Freedom (DOF) to Pressure DOF. However, when the nodes at the contact interface do not match, there might be a discontinuity in the pressure distribution, particularly at high frequencies. Therefore, it's recommended to conduct a verification case to assess this impact.
For detailed information on this topic, please refer to the document and simulation model below.
You are being redirected to our marketplace website to provide you an optimal buying experience. Please refer to our FAQ page for more details. Click the button below to proceed further.
