How to evaluate reaction force on construction surface?
We can plot reaction force on construction surface. To do so, first you need to turn on the Nodal Force option available under output control option in analysis settings.
After that select, the surface as location method, construction surface as a surface in detail view of force reaction to post process the force reaction on construction Surface.
