Inductance calculations in Switched Reluctance Machines - II — Lesson 6
This lesson covers the process of calculating the inductances of a Switched Reluctance Machine (SRM) using an analytical approach. It explains the concept of flux paths and how to calculate the length of these paths. The lesson also discusses how to find the cross-sectional area with respect to the stator pole region and how to analyze the magnetic equivalent circuit. The lesson further explains how to calculate the reluctance and the flux with respect to the path. Finally, it provides a detailed explanation on how to calculate the inductance in aligned, unaligned, and intermediate positions.
Video Highlights
00:00 - Introduction
00:55 - Discussion on finding the length of flux paths
05:08 - Explanation of cross-sectional area calculation
08:09 - Analysis of the magnetic equivalent circuit
09:53 - Calculation of reluctance and flux
12:39 - Calculation of inductance in aligned, unaligned, and intermediate positions
Key Takeaways
- The inductance of a Switched Reluctance Machine (SRM) can be calculated using an analytical approach.
- The calculation involves understanding the concept of flux paths and calculating their lengths.
- The cross-sectional area with respect to the stator pole region is crucial in the calculation.
- The magnetic equivalent circuit analysis helps in understanding the flow of the leakage flux.
- The reluctance and flux with respect to the path are calculated to determine the inductance in aligned, unaligned, and intermediate positions.
