This lesson covers the design equations for the stator of a switched reluctance machine. It explains how to calculate the volume of a machine, the number of turns per phase, the stator phase current, and the cross-sectional area of the conductors. The lesson also discusses how to select the number of phases and poles in a switched reluctance machine, considering factors such as power, torque density, fault tolerance, starting capability, and cost. It further elaborates on how to calculate the slot height, pole height, slot area, and back iron thickness. The lesson concludes with the calculation of flux densities at different parts of the iron.
00:00 - Introduction to design equations for stator and rotor
02:33 - Calculation of the number of turns per phase
06:30 - Selecting number of phases
11:23 - Selection of the number of poles
13:34 - Calculation of pole height and pole depth
26:24 - Calculation of slot area of the stator
- The number of turns per phase in a switched reluctance machine can be calculated using the voltage equation.
- The number of phases and poles in a switched reluctance machine should be selected based on power, torque density, fault tolerance, starting capability, and cost.
- The flux densities at different parts of the iron can be analyzed to determine the appropriate design parameters.
