Consider the geometry in the figure below. The slender bar is 3 inches wide, 2 inches tall, and 50 inches long. The large block on the end of the bar is 9 inches wide, 6 inches tall, and 6 inches long. Both are made of structural steel with a Young’s modulus of 2.90075E+7 and a Poisson’s ratio of 0.3. The left end of the bar is fixed to a wall, and the geometry is subjected to standard earth gravity. Calculate the maximum equivalent stress in the geometry.
