Voltage Generation in Single Conductor Motor — Lesson 4
This lesson covers the concept of voltage generation in conductors, specifically focusing on single conductor motors. The lesson explains how voltage is generated when a conductor moves through a magnetic field, and how the voltage changes depending on the direction of the field. It also discusses the concept of flux density and how it affects the voltage generated. For instance, if the flux density is distributed in a rectangular manner, the voltage will also be rectangular and alternate. The lesson further explores the concept of induced voltage and how it varies depending on the flux density distribution. For example, if the flux density distribution is sinusoidal, the induced voltage will also be sinusoidal.
Video Highlights
01:16 - Explanation of how voltage changes depending on the direction of the magnetic field
04:55 - Discussion on the concept of flux density and its effect on voltage
06:45 - Explanation of induced voltage and how it varies with flux density distribution
11:13 - Discussion on the effect of conductor placement on voltage generation
Key Takeaways
- Voltage is generated when a conductor moves through a magnetic field.
- The voltage generated depends on the direction of the magnetic field.
- Flux density affects the voltage generated in a conductor.
- The induced voltage in a conductor varies depending on the flux density distribution.
- The placement of conductors can affect the voltage generated.
