Basics of Rotating Machines — Lesson 6
This lesson covers the fundamental concepts of rotating machines, focusing on the structure and operation of stator and rotor. It explains how the stator and rotor, both having coils that carry current, produce a pair of poles that interact to generate torque. The lesson also discusses the importance of an air gap between the stator and rotor for smooth rotation. It further elaborates on the concept of pole pitch and slot pitch, and how the placement of coil sides under the pole pitch optimizes the induced voltage. The lesson concludes with the common underlying principle of operation for all electrical rotating machines.
Video Highlights
00:51 - Explanation of stator and rotor structure
03:37 - Discussion on pole pitch and slot pitch
07:26 - Understanding the interaction of stator and rotor fields
09:33 - Explanation of the operation of a motor
22:50 - Discussion on the common underlying principle of operation of electrical machines
Key Takeaways
- Rotating machines consist of a stator and a rotor, both having coils that carry current.
- The stator and rotor each produce a pair of poles (North and South) that interact to generate torque.
- The placement of coil sides under the pole pitch optimizes the induced voltage.
- An air gap between the stator and rotor is necessary for smooth rotation.
- All electrical rotating machines operate based on the common underlying principle of interaction between the stator and rotor fields.
