This lesson covers the transport phenomena of Non-Newtonian fluids, focusing on the quasi-steady analysis of simultaneous heat transfer, mass transfer, and chemical reactions. It delves into the problems where simultaneous heat and mass transfer occur, along with reactions. The lesson explains the concept of pseudo steady state or quasi steady analysis and how it incorporates time information. It uses the example of a combustion of a carbon particle to illustrate the concepts. The lesson also discusses the mathematical equations and assumptions used in the analysis, including the Peclet number, reaction rates, and fluxes at the surface.
02:01 - Discussion on the combustion of a carbon particle and the chemical reactions involved.
09:10 - Determination of the oxygen flux at the surface and the heat flux and reaction rate at the particle.
54:45 - Explanation of the energy conservation in the gas and the derivation of the equation for the temperature profile.
61:04 - Conclusion of the lecture with the final expression for the surface temperature.
