Lesson 1 - Project Setup and Processing
In this lesson you will learn how to set up and run a SAOR test case using a cylinder and a tray.
You will work with the following features:
- 3D View Window.
- Contact Model (Adhesive Forces): Constant.
- Walls (import *.xgl, *.stl, and *.dxf Files).
- Custom Inlets.
- Modify Material Compositions.
- Motion Preview Window.
- Rolling Resistance Model: Type C: Linear Spring Rolling Limit (Type 3).
- Sieve Size.
- Spherical Shape.
- Translation.
- User Manual.
- Volumetric Inlet.
Simulation Files
Download the files here to follow the tutorial step-by-step.
