Microwave Amplifier Stability Analysis — Lesson 2
This lesson covers the concepts of power gains in microwave amplifiers, including transducer power gain, available power gain, and simple matching techniques. It explains how power gains depend on load and source impedances, and introduces the concept of conjugate matching for achieving maximum power transfer. The lesson also discusses unilateral amplifiers, where certain parameters simplify the design process. Additionally, it delves into amplifier stability, explaining conditions for unconditional, conditional, and potential instability. For example, if the input impedance of an amplifier has a negative real part, it can lead to oscillations, making stability checks crucial. The lesson concludes with an introduction to stability circles for designing conditionally stable amplifiers.
Video Highlights
00:20 - Introduction to Power Gain Definitions
02:15 - Available Power Gain and Its Independence from Load Impedance
05:04 - Simple Matching vs. Conjugate Matching
12:17 - Generalized Microwave Transistor Design with Matching Networks
22:31 - Unconditional Stability Criteria
29:03 - Introduction to Stability Circles for Potentially Unstable Amplifiers
Key Takeaways
- Power gains in microwave amplifiers depend on load and source impedances, with conjugate matching enabling maximum power transfer.
- Simple matching techniques, such as setting source and load impedances to real values, can simplify designs but may not ensure maximum power transfer.
- Unilateral amplifiers simplify design calculations by assuming negligible reverse transmission (S12 ≈ 0).
- Amplifier stability is critical; instability can occur if input or output impedances have negative real parts, leading to oscillations.
- Stability checks involve ensuring reflection coefficients (gamma_in and gamma_out) are less than one for all passive source and load conditions.
