Please watch the following videos for a demonstration of Physics Setup in Fluent:
Before watching this tutorial video, please download the injection file: injection_onlyatshear400.inj
Quick summary of the points covered in the video above:
Before watching this video, please download the files needed in this case:
Initial velocity field data file: IC.dat
User Defined Function (UDF) for reading the data file into Fluent: define_init.c
Case file, Data file and compiled UDF library (download this if you have trouble compiling UDF): Case and data and compiled UDF.zip
There is an ERROR in the DENSITY VALUE given in the video. Please use the density values given in the table below instead!
The density to use for three different cases:
As we have discussed in the Pre-analysis and Setup section, the Stokes number is the ratio of particle response time to the flow characteristic time scale. Here, in the case of low Reynolds number flow, particle response time is calculated using this formula:
Here, we will use the inverse of the instability growth rate as the flow characteristic time scale:
Combining the two equations above, we get:
