Understanding Particle Image Velocimetry — Lesson 3
This lesson covers the detailed aspects of Particle Image Velocimetry (PIV), a technique used to measure velocity fields. It delves into the intricacies of light sheet optics, the role of lenses in generating light sheets, and the importance of cylindrical lenses. The lesson also discusses the use of different types of cameras, including high-speed film cameras and digital cameras, and their role in PIV applications. It further explains the post-processing of raw data, the significance of synchronization, and the challenges of performing PIV studies with moving boundaries. The lesson concludes with practical examples of PIV applications in experimental setups.
Video Highlights
01:11 - Explanation of the role of cylindrical lenses in generating light sheets.
08:14 - Explanation of the process of obtaining velocity vectors from displacement vectors.
24:16 - Discussion on the challenges of performing PIV studies with moving boundaries.
30:21 - Explanation of the use of tomographic or volumetric PIV for capturing 3D flow fields.
Key Takeaways
- Light sheet optics and cylindrical lenses play a crucial role in illuminating tracer particles in PIV.
- Different types of cameras, including CCD and CMOS cameras, are used in PIV applications.
- Post-processing of raw data involves correlating image information between two sequential images to obtain the displacement vector and velocity vector for each particle.
- Synchronization is crucial in controlling the timing of laser illumination and camera data acquisition.
- Performing PIV studies with moving boundaries is more complex than with fixed boundaries.
- Practical examples of PIV applications include studying the velocity field around a flapping wing and analyzing the spatial development of a subsonic jet.
