In Fluent, go to File-Write-Case&Data at the top menu.
Open CFD-Post and click File-Load Results. Select the data file that you just wrote as the file to load.
Create contours of:
To do this, click the Contour button at the top menu
In the pop-up dialogue box, name the contour after the variable that it will display and click "OK." For all contour plots, select "periodic 1" for the location and increase the number of contours to 51. Change the drop-down box under Variable to the variable that you would like to create the contour of. Click "Apply" to generate the contour and repeat this process for all contours.
Stream Function:
Progress Variable:
Temperature:
Mass Fraction of CH4:
Turbulent Flame Speed:
