Process Integration in optiSLang UI — Lesson 4
This lesson provides step-by-step guidance on how to perform LS-DYNA process integration in the optiSLang UI.
Download the provided input and output files from the course attachment. These files are ready to use, so you can immediately begin to follow the instructions on how to connect the LS-DYNA process to optiSLang software.
The successfully completed workflow provides the basis for parametric variant analysis in the subsequent lessons.
Lecture
Alternate video link.
Video Highlights
00:09 – Get started using the solver wizard
00:35 – Step 1: Select LS-DYNA as solver
00:41 – Step 2: Parametrize input file
02:00 – Step 3: Define parameter properties
02:14 – Step 4: Parametrize solver outputs
05:22 – Step 5: Define criteria
05:36 – Step 6: Define the solver process
06:26 – Extend the created basic workflow
07:28 – Start test run
Simulation Files
Download the accompanying files used in the video lesson here. Ansys Student can be downloaded for free here.
