Once again, a wizard is used to easily set up a multi-objective optimization in this lesson.
Due to its very good prediction quality, the AMOP can be used to approximate the responses with sufficient accuracy. Thus, the optimization process can be performed in less time compared to time-consuming numerical simulations. Nevertheless, it will be shown how to validate the best designs along the Pareto front.
Furthermore, the lesson will demonstrate how to easily evaluate and comprehensibly visualize the results in post-processing.
00:09 – Step 1: Start using the optimization wizard
00:36 – Step 2: Define optimization criteria
00:57 – Step 3: Choose the optimization method
01:08 – Step 4: Additional optimization options
01:31 – Reducing the number of Pareto designs to be validated
01:51 – Multi-objective optimization postprocessing
02:08 – Control validated design
