Transverse Vibration of Strings — Lesson 3
This lesson covers the concept of transverse vibration of strings, focusing on the formulation of the equation of motion and its solution. It delves into the aspects of transverse vibration, including material frequencies, mode shapes, orthogonality of mode shapes, and the decoupling of the equation of motion. The lesson also discusses the vibration of a string subjected to initial conditions. It uses the example of a string of finite length to illustrate the concepts. The lesson further explains the separation of variable technique used to solve the free vibration transverse vibration of a string subjected to uniform tension.
Video Highlights
01:04 - Aspects of the transverse vibration of string.
04:10 - Wave equation and its solution using the separation of variable technique.
10:49 - Properties of mode shapes and natural frequencies.
34:46 - Orthogonality of mode shapes.
41:20 - Transverse vibration of a string subjected to initial conditions.
Key Takeaways
- Transverse vibration of strings involves the formulation of the equation of motion and its solution.
- The aspects of transverse vibration include material frequencies, mode shapes, orthogonality of mode shapes, and the decoupling of the equation of motion.
- The separation of variable technique is used to solve the free vibration transverse vibration of a string subjected to uniform tension.
