Bingham Plastic Fluids Flow through Pipes — Lesson 3
This lesson covers the transport phenomena of non-Newtonian fluids, specifically focusing on Bingham Plastic Fluids flowing through pipes. It delves into the velocity profile, volumetric flow rate expressions, and friction factor equations for different types of generalized Newtonian fluids. The lesson also discusses the equations for velocity profile and volumetric flow rate when the fluid is of power law type and Ellis model fluid. It further explains the concept of viscoplastic fluids and how their velocity profile changes when flowing through a pipe. The lesson concludes with a detailed example problem that illustrates the application of these concepts in real-world scenarios.
Video Highlights
01:23 - Derivation of the shear stress expression for Power-law fluids.
11:51 - Derivation of the velocity profile for viscoplastic fluids in the deforming region and solid plug-like region.
29:10 - Calculation of the volumetric flow rate for viscoplastic fluids.
38:38 - Explanation of the friction factor for Bingham plastic fluids.
42:08 - Solution of an example problem related to the flow of Bingham plastic fluids.
Key Takeaways
- The velocity profile, volumetric flow rate, and friction factor equations vary for different types of generalized Newtonian fluids.
- Bingham plastic fluids have a unique flow pattern through pipes, which can be understood through specific equations.
- Viscoplastic fluids have a distinct velocity profile when flowing through a pipe, which is divided into a solid plug region and a deforming region.
- Understanding these concepts is crucial for solving real-world problems related to fluid flow.
