Simulation Examples, Homework and Quiz
Here we will go over several simulation examples and homework assignments that demonstrate the fundamentals discussed in the previous lessons. Each example contains a video walkthrough to be used for recreating the flow simulation and a slide deck that discusses results and settings. An Ansys Fluent Mesh file is provided for setting up the simulation based on the walkthrough. Initial and final Case and Data files have also been provided for reference. All of the simulations are conducted using Ansys Fluent. You can download the student version of Ansys software here. If you are new to Ansys Fluent, please check out this short video on the Fluent Workspace user interface.
After going through the simulation examples and homework, you can test what you learned in this course by answering the questions in the final quiz.
