This lesson covers the concept of Time Division Multiple Access (TDMA) in satellite communication. It delves into the characteristics of TDMA, including its synchronization, transmission rate, and the role of a reference station. The lesson also explains the process of burst transmission and reception, the detection of unique words, and the probability of misdetection and false detection. It further discusses the concept of closed-loop and open-loop synchronization, and the use of GPS for precise timekeeping. The lesson concludes with an exploration of advanced TDMA systems like Satellite Switched TDMA and the calculation of transponder utilization.
00:20 - Introduction
01:23 - Closed loop synchronization and how it works
04:15 - Open loop synchronization and how it can be achieved with systems like GPS
08:02 - Transponder utilization
10:28 - Finding number of channels
12:36 - Example problems
18:57 - Satellite switched TDMA (SS-TDMA) and how it works
22:21 - Issues in TDMA
- TDMA is a method of transmitting and receiving independent signals over a common signal path by means of synchronized switches.
- In TDMA, each station is assigned a specific time slot for transmission, ensuring efficient use of the available bandwidth.
- The synchronization of TDMA involves a reference station that provides frame timing to all other stations.
- Closed-loop synchronization involves adjusting the transmission time based on the reception of the burst, while open-loop synchronization uses an independent system like GPS for precise timekeeping.
- Advanced TDMA systems like Satellite Switched TDMA can support a higher number of users by quickly switching between beams.
