This lesson covers the concept of noise temperature in systems, focusing on internal and external noise contributions. It explains how to calculate equivalent noise temperature for a two-port network and explores the impact of antenna efficiency and amplifier gain on noise power. The lesson also introduces cascaded systems and Friis' formula to determine overall noise contribution. Practical examples, such as calculating noise power for a receiver with matched load conditions, are discussed. Additionally, the lesson explains noise factor and noise figure, their relationship with effective noise temperature, and the significance of standard temperature (290 Kelvin) in calculations. For instance, the lesson demonstrates how a low-noise amplifier minimizes noise contribution in a receiver chain.
00:17 - Antenna and source noise
02:45 - Receiver Noise Temperature and Amplifier Gain
07:11 - Output Noise Power Calculation for Amplifier
10:03 - Cascade Connection of Amplifiers and Noise Contribution
17:56 - Noise Bandwidth and Practical System Considerations
22:42 - Receiver noise factor
25:01 - Standard Noise Temperature and Noise Factor Calculation
- External and internal noise sources contribute to the total noise power in a system, which can be represented by an equivalent noise temperature.
- Antenna efficiency and attenuation impact the noise power calculation, with efficiency expressed as a fraction (e.g., 0.9 for 90%).
- Friis' formula is used to calculate the overall noise temperature in cascaded systems, where the first component's noise contribution is dominant.
- Low-noise amplifiers are crucial in receiver design to minimize the noise contribution from the first component.
- Noise factor and noise figure are key parameters for quantifying noise contribution, with standard calculations often based on a temperature of 290 Kelvin.
