Basic concepts in Dynamic Measurements III — Lesson 3
This lesson covers the concept of dynamic measurements in fluid mechanics, focusing on the difference between static and dynamic measurements. It explains that static measurements are simpler and involve flow variables that are constant over time, while dynamic measurements are more complex and involve flow variables that change over time. The lesson also discusses the factors that must be considered in dynamic measurements, such as mass or inertia, stiffness or resistance, and damping or capacitance. It further delves into the mathematical modeling of dynamic measurements using a second-order ordinary differential equation. The lesson concludes with an example of how to interpret the amplitude ratio and frequency ratio in dynamic measurements.
Video Highlights
01:01 - Explanation of the difference between static and dynamic measurements
02:35 - Introduction to the concept of dynamic measurements and its complexity
06:12 - Discussion on the mathematical modeling of dynamic measurements using a second order ordinary differential equation
15:57 - Discussion on the use of Fourier series expansion or Fourier integral to decompose the forcing function into sine and cosine functions
23:59 - Explanation of the solution to the differential equation when the forcing function is periodic
29:00 - Discussion on the variation of amplitude ratio with frequency ratio for different damping ratios
38:15 - Explanation of the terms under damped and over damped in relation to damping ratios
Key Takeaways
- Dynamic measurements in fluid mechanics are more complex than static measurements and involve flow variables that change over time.
- Factors such as mass or inertia, stiffness or resistance, and damping or capacitance must be considered in dynamic measurements.
- Dynamic measurements can be mathematically modeled using a second-order ordinary differential equation.
- The amplitude ratio and frequency ratio in dynamic measurements can provide valuable insights into the behavior of the system.
