Building and Publishing Custom Library in Ansys Lumerical INTERCONNECT — Lesson 2
Add to Custom Library
In this video lesson, you will learn how to add (custom) elements to the custom model library in INTERCONNECT. The project file including the ring modulator compound element used in the video can be downloaded here.
Publish Custom Library
The following video lesson walks you through the process of publishing and sharing a compact model library in INTERCONNECT.
The compact model library file used in the video can be downloaded here.
CML Distributions
Capabilities
Public: Supports open collaborative CML development. Does not require any special license to publish or install/use the CML. End users can see all details about how the compact models are created.
Protected: Enables obfuscation of underlying data and locking of hierarchical model definitions. Requires a special license to publish the CML but no special license is needed to install/use it. End users cannot see the details of how the compact models are created.
