The device under investigation is a simple silicon strip waveguide fabricated on an SOI (silicon-on-insulator) wafer. The strip waveguide has a height of 220 nm and a width of 500 nm. The waveguide is surrounded by an oxide (SiO2) cladding.
Since the waveguide is uniform in the propagation direction, we can perform an eigenmode analysis on its cross-section using the mode solver to:
Please login to continue:
RETRY
