Each structure object in the simulation is assigned a material. In the materials tab of the structure edit window, you can choose to use the <Object defined dielectric> material and type in the refractive index (can be spatially-varying), or select another material from the material database.
The (n,k) import object can also be used to specify a spatially-varying refractive index. More information can be found here.
Material database
Material explorer
Modeling dispersive materials and material fitting
Advanced capabilities
Please login to continue:
RETRY
