In this video lesson, you will learn about some essential checks before running your simulations. You will also learn about layout and analysis modes.
In this video lesson, you will learn how to access the simulation results recorded in the monitor and visualize them.
In this video lesson, you will learn how DGTD compares with FDTD using the same Mie scattering example in terms of meshing and convergence. You will also learn about a few cases where DGTD has a performance advantage over FDTD.
