Setting Up the Simulation Using Ansys Lumerical CHARGE — Lesson 2
In this Lesson, we will guide you through setting up the simulation of a simple p-n junction diode as your first simulation in Lumerical CHARGE. A completed simulation project file can be downloaded here if you do not want to follow along with the video or want to compare your setup with this file as a reference.
