This lesson covers the principles of kinetics, specifically focusing on the action of forces on rigid bodies. It begins with a recap of Newton's second law, explaining how force causes acceleration and the role of mass in this process. The lesson then delves into the laws of motion that govern plane kinetics of rigid bodies, including Euler's Laws of motion. It explains the concept of the center of mass and how it is defined. The lesson also discusses the additional degrees of freedom that a rigid body has, such as the ability to rotate, and how this affects the laws of motion. It concludes with an explanation of the conservation of angular momentum and how moments are calculated.
00:04 - Introduction to the study of kinetics and forces on rigid bodies
00:42 - Recap of Newton's second law
03:15 - Definition and explanation of the center of mass
06:10 - Explanation of Euler's Laws of motion
08:50 - Discussion on the conservation of angular momentum
