This lesson covers the concept of lossy transmission lines, focusing on the characteristics of a special form of lossy line known as the distortionless line. It explains the complex propagation constant and how it is calculated in terms of line parameters. The lesson also discusses the practical cases of transmission line losses and how to simplify the expression for parameters. It introduces the concept of a distortionless line, which does not distort the signal. The lesson further explains the input impedance of a lossy transmission line and the power in a terminated lossy line.
00:28 - Introduction to the lossy transmission line
03:32 - Low loss case in lossy lines
07:22 - Introduction to the distortionless line
14:22 - Terminated lossy lines
19:06 - Explanation of the power in a terminated lossy line
21:58 - Discussion on the power lost in the line
- The complex propagation constant for a transmission line is given by gamma, which is equal to alpha (the attenuation constant) plus j beta (the phase constant).
- In practical cases, transmission line losses are usually small and some approximation can be made to simplify the expression for the parameters.
- A distortionless line is a special type of lossy line that does not distort the signal.
- The input impedance of a lossy transmission line can be calculated using hyperbolic functions.
- The power in a terminated lossy line can be calculated, and the difference in power corresponds to the power lost in the line.
