This lesson covers the subject of failure analysis and prevention, focusing on the different aspects related to the failure of engineering components. It discusses the importance of failure analysis and provides examples of major engineering disasters in history that have led to significant loss of life and property. The lesson also explains the conditions under which a component is considered to have failed, such as when it is inoperable, does not perform its intended function, or when its reliability and safety are compromised. It further delves into the four broad categories of mechanical component failures: unacceptable elastic deformation, unacceptable plastic deformation, complete fracture, and loss of dimensions beyond acceptable limits due to wear and tear. The lesson concludes by discussing the four fundamental causes of mechanical component failures: design, material, manufacturing, and service conditions..
0:18 - Introduction to the subject of failure analysis and its importance -
2:28 - Detailed analysis of the Titanic ship failure
7:18 - Explanation of the Saint Francis dam disaster
11:34 - Explanation of the Bhopal disaster
22:41 - Explanation of the four ways mechanical components can fail
35:10 - Detailed discussion on the fundamental causes of mechanical component failure
- Failure analysis is crucial in preventing engineering disasters and ensuring the safety and reliability of components.
- A component is considered to have failed when it is inoperable, does not perform its intended function, or when its reliability and safety are compromised.
- Mechanical component failures can occur due to unacceptable elastic deformation, unacceptable plastic deformation, complete fracture, and loss of dimensions beyond acceptable limits.
- The four fundamental causes of mechanical component failures are design, material, manufacturing, and service conditions.
