As we saw in Lesson 1, performance indices are identified by using the function, constraints, and objectives from the Translation step of the materials selection methodology.
Each of these steps identifies an expression of interest that is combined to get a performance index.
In this lesson, we will go through a case example of how to derive a performance index for a given function, constraint, and objective.
Please use the provided handout on the course homepage to follow along with the lesson. References (such as those highlighted at the end of this lesson) and relevant links can be found in the Relevant Links lesson tab.
