Properties of Fluids — Lesson 2
Why does oil float on water?
How many drops of water can we put on top of a coin before it spills? What holds this water on the coin even after all the surface area is covered?
We will learn the definition of a fluid. A fluid is characterized by properties such as density, viscosity, surface tension, and pressure. We will define these properties and study their importance.
Alternate video link.
Here are the accompanying handout slides for this lesson.
