Summary
  • Layered composites are anisotropic, meaning their mechanical properties can change based on the direction in which they are measured. This is different from metals, which are isotropic and have uniform properties in all directions.
  • The failure modes in layered composites are more complex than in metals. Composites can fail due to a variety of mechanisms including fiber breakage, matrix cracking, and delamination.
  • Layered composites can be more sensitive to environmental factors like temperature and humidity. These factors can affect their properties and performance.
  • The properties of layered composites can be significantly affected by variations in the manufacturing process. Factors such as the alignment and distribution of the fibers, the quality of the bonding between layers, residual stresses developed during curing, and the presence of defects, all play a crucial role.
  • Micro-mechanical models are designed to consider scenarios where the alignment of the composite layers may make it impractical to anticipate the onset and propagation of cracks using large scale finite element analysis (FEA) models.
  • Understanding failure modes is crucial to the design of robust, resilient composite materials. These include failures that occur within a layer and failures that occur between layers, often called delamination.
  • Failure criteria for layered composites can be grouped into three categories based on how they evaluate failure.
  • The first group considers stress in a single direction and do not account for interactions between stress components. Maximum Strain Failure Criteria and Maximum Stress Failure Criteria come under this group.
  • The second group includes criteria that consider interactions between stress components, such as the Tsai-Wu and Tsai-Hill Criteria.
  • The third group includes criteria that account for different fiber and matrix failure modes separately, such as the Puck, Hashin, and LaRC Criteria.
  • There are some unique failure criteria for the failure of sandwich composites. These include Core Failure, Face Sheet Wrinkling, and Shear Crimping Failure.
  • Failure indicators in a layered composite material include the First-Ply-Failure or FPF indicator and the Last-Ply-Failure, or LPF. These indicators help determine the reserve factor, inverse reserve factor, or margin of safety.
  • Delamination and Debonding are two other key types of failure in composites. Delamination typically refers to the interface failure between two plies, while Debonding typically refers to the interface failure between laminates, between a laminate and mating part, or even between the face sheet and core of a sandwich structures.
  • The strength of a laminate is influenced by many factors, such as the orientation of layers, strength of the fiber and matrix, stiffness, stacking sequence, fabrication process, environmental factors, etc.
  • First Ply Failure (FPF) is a method used to evaluate the strength of layered composites by identifying potential failure points. It is based on the fact that not all layers of a composite fail at the same time.
  • FPF is evaluated through failure plots that display the critical first ply failure safety factor for a given failure criteria definition.
  • There are three main safety factors used to measure FPF:
  • Reserve Factor (RF) is an indication of the margin to failure. When RF is less than 1, the ply is considered to be failed under the applied load.
  • Inverse Reserve Factor (IRF) is the inverse margin to the Reserve Factor. When the IRF exceeds 1, it indicates that failure has occurred.
  • Safety Margin or Margin of Safety (MoS) is obtained from the Reserve Factor or the Inverse reserve Factor. A positive MoS shows the extent to which the load applied can be increased before failure load is reached, while a negative MoS shows the extent to which the load applied must be reduced.
  • By understanding the indicators, we can better predict and prevent potential failures in composite structures.
  • The FPF method involves defining the layup, applying appropriate loads and boundary conditions, solving the simulation model, evaluating the FPF indicators, visualizing the results for each layer, and making necessary changes to the layup to increase the overall strength.
