Industrial engineering tool for failure analysis: Fishbone diagram and FMEA — Lesson 3
This lesson covers the subject of failure analysis and prevention, focusing on the application of industrial engineering tools. It discusses the use of the Pareto diagram to identify vital factors affecting product or process performance. The lesson also introduces the Fishbone or Ishikawa diagram, a qualitative tool that uses a team-based approach to identify major and minor causes related to failure. The lesson further delves into the Failure Mode and Effect Analysis (FMEA), a preventive technique that helps identify potential failure modes in a system, their causes, and effects. For instance, it explains how FMEA can be used to prioritize risks associated with various components in a system.
Video Highlights
01:10 - Introduction to the Fishbone or Ishikawa diagram, its history, and its use in analyzing causes of failure.
06:51 - Discussion on the importance of having a team from different functions to identify potential deficiencies in design, materials, manufacturing, service, maintenance, and assembly.
19:47 - Introduction to Failure Mode and Effect Analysis (FMEA) and its use in identifying risk priority numbers related to product failure.
29:49 - Detailed examples of FMEA application in manufacturing, design, and software.
Key Takeaways
- The Pareto diagram is a useful tool for identifying vital factors that significantly affect product or process performance.
- The Fishbone or Ishikawa diagram is a qualitative tool that helps identify major and minor causes related to failure.
- The Fishbone diagram is also known as a cause and effect diagram.
- Failure Mode and Effect Analysis (FMEA) is a preventive technique that helps identify potential failure modes in a system, their causes, and effects.
- FMEA can be used to prioritize risks associated with various components in a system.
