How To Solve Interference Fit Problems — Lesson 2
An interference fit is a commonly used technique in mechanical design where one part is installed into another in a way that the frictional force between them keeps them engaged. This feature is modeled in FEA by using robust contact algorithms. It is typically a nonlinear analysis, but with a little care it is easy to solve. In this video, we will show how to set it up in Ansys Mechanical and solve and interpret the results.
Simulation Files
Download the accompanying geometry and archived files here. The student version of Ansys simulation software can be downloaded here.
