The goal of this lesson is to validate Explore-Mode results by comparing them with Refine-Mode results in Ansys Discovery. Refine-Mode leverages Ansys’ flagship technologies both for meshing and solving. This part explores simulation and meshing options in Refine-Mode, where physics conditions and local fidelity settings from Explore-Mode are transferred. Additional simulation options, including convergence settings, solver selection, turbulence modeling, and meshing methods, are covered. The module focuses on using the LiveGX solver and Polyhedra meshing that are both available also in Ansys Fluent.
If you're new to this setup, consider reviewing the last lesson or downloading the provided setup file for a seamless start. This part continues to use the *.dsco file provided in the previous lesson, it can also be found here.
Simulation Files
Download the files here to follow the video step-by-step. Ansys Student can be downloaded for free here.
Please login to continue:
RETRY
